跳转到主内容
加入维修社区 - 创建账户
发布于 2013 年 3 月,型号为 S500CA-SI50305T
How to boot from sad using USB boot windows 10
Hello,
I'm hoping to install an ssd in my laptop I'm planning on installing it completely blank then boot the laptop from a USB. Once I boot it from the USB will windows go right to the ssd or will I have to do something to save windows to the add so I can boot it up normally without the USB but instead from the ssd.
Thanks,
-Brad
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Brad --
You must install Windows on the new SSD before it will boot. If this is a replacement, I suggest that you clone the old drive onto your SSD before installing. There is free software available on the web that will do that.
Good luck,
Russ
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Brad 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 352
