跳转到主内容
Released in March 2013, identified by model number S500CA-SI50305T
12 个问题 查看全部
Will I need a new windows 10 key?
I bought an asus s500ca without a hard drive I'm hoping to use a usb boot I downloaded from Microsoft and I was wondering if when I boot it up with this usb will I need to enter a new product key?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
What operating system originally came with this laptop? Both Windows 10 and 8 in later models had keys embedded in the motherboard. When you install, it will self activate with those keys.
这个答案有帮助吗?
得分 5
1条评论:
I'm here to second that. I work in PC repair and if it is a Windows 8 or above PC with an embedded key it should just activate.
完成的
添加一条评论
It should let you skip applying a serial code. It will notify you continuously though. There are some sites that give out codes (cant post here). Be wary on such sites as many are a bit sketchy
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Brad 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 533
