跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy Tab 4 10.1 是三星推出的第四代平板电脑,拥有更大的屏幕、更高的摄像头分辨率和 1.5 GB 运行内存。
Touch not v smooth
I changed the battery and the lock for one cable broke. Touch not consistent . Everything else v good
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
Is the broken lock on the cable for the digitizer (touchscreen)?
If so try holding down the cable in the connector, initially with some tape to ensure that it is not loose and is making a good connection i.e. when cable is firmly inserted to connector, tape across the top of the cable connector and cable to the case or board or wherever so as to hold it in securely. Try not to cover components etc if attaching to the board.
If this solves the touch problem, use small dobs of silicon sealant (neutral cure) to permanently hold the cable in position.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Munji Mo 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 15
总计 302
