跳转到主内容
加入维修社区 - 创建账户
LG K7 是一款 LG 在 2016 年 2 月发布的智能手机,运行 Android 5.1 系统。
Wifi calling connection not working.
My home is in a weak cell network location -- 1 or 2 bars at best. Although I have an excellent wifi network connection from my LG K7 to my home Comcast router, I'm unable to maintain a constant wifi calling connection at home. Other outside router connections to wifi calling seem to work well.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论:
I can get calls in but can't call out.just started last week off and on .now can't call out at all.my internet provider is frontier. I have basically the same problem as Edward Driscoll i have a strong wifi signal
由完成的
添加一条评论
2个答案
make sure you have data all the way off or it could bottleneck the speed of your wifi
这个答案有帮助吗?
得分 0
添加一条评论
I had the same problem and I just found the solution for me. I had to log onto my router (Lynksys connected to my Comcast modem) and disable IPv6. IPv6 uses longer IP addresses; LG K7 only supports the shorter addresses used in IPv4. So when I had both IPv6 and IPv4 enabled, my phone sometimes got sent the longer address, which caused it to not connect. Turning off IPv6 makes it work all the time now for me.
Hope this helps.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Edward Driscoll 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 13
总计 1,555
