跳转到主内容
The Kenmore Elite HE3 is a washing machine by Kenmore. It is identical to the Whirlpool Duet.
Why is it flashing F and H in display window
turn on normal cycle, was fine for about 3-4 min, started to beep and flash H and F in display window
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
3条评论
I have the same problem! Help!
完成的
i have the same problem..!! need help anyone..please..!!
完成的
that didnthelp
完成的
添加一条评论
1个答案
已选择的解决方案
I believe that those are error codes....isn't it great to have a washer that checks itself :) anyhow some of the codes are
“F20” (Water Inlet Problem—no water or insufficient water supply)
Select STOP twice to cancel the cycle. Unplug washer or disconnect power.
“F21” (Drain Problem)Select STOP twice to cancel disconnect power.
“SUD” (Suds Routine)When excessive suds are detected, a suds routine
automatically starts. This routine removes extra suds and assures proper rinsing of your garments. “SUD” is displayed during rinsing to inform you that Suds Routine was activated.
“F22” (Front door lock)Select STOP twice to cancel the cycle.
“F” Codes other than F20, F21 and F22
Select STOP twice to cancel the cycle. Select if there is excessive water in the washer.
I believe that the HF is the error code for a water inlet issue. You need to ensure that the unit is getting both hot and cold water if so the pressure switch will need to be replaced. The switch is located on the top right of the unit.
These should be in your user manual. Hope this explains a little bit about your display. Good luck
这个答案有帮助吗?
得分 1
1条评论:
http://www1.epinions.com/msg/show_~threa... where they are talking more about it and better than I can....:)
完成的
添加一条评论
添加你的答案
rita kerr 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 4,127
