Is my router/modem outdated
Hi I was wondering is my router outdated..here are some signs
1. Disconneting every 1-5 mins (Xbox and Laptop)
2. Very slow (1.65m) which should be 60 or higher
3. We call Mediacom to fix the router and it still didn't change whatsoever after he left.
4. It is 7 years old
5. I did power cycle,factory reset, everything and still don't work.
I'm wondering if it's outdated or just malfunction .
Btw only 3 ppl are using it so yea.
Is the modem/router together? What is the brand / model of the router and/or modem?
由 S W 完成的
Hi,
Has it got the latest firmware installed?
Is it a WiFi router? If so have you tried using a WiFi scanner program to see if the channel that you are using is being"shared' by other users (not your network but other networks nearby with a strong signal) which may be causing interference problems and slowing your connections?
由 jayeff 完成的
