跳转到主内容
What is matching RAM?
I have the 512MB RAM (original) and added an extra 1GB on the second slot. I get problems once in a while with computer freezing specially when running apps that require lots of memory or running multiple apps.
I left the 1GB only and I do not get these problems. Does this have to do with this being not matched memory? Could you please explain what this means or how it works.
I would like to get another 1GB to have the max 2GB installed but I would like to know how to buy a matching one or at least make sure it will work
thanks
Jose
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
It depends on how specific you are about speed matching, and any potential problems. if you want it to work correctly and not have a problem you will want to match the modules exactly. If you just want the speed to match, you can buy a module of the same speed and match the speeds. These 2 options are what I suggest doing.
If you aren't concerned about any of that and just want to get more memory, you can mix and match speeds and brands as long as you are okay with the new module taking the speed of the original module(s) that came with the computer. I don't suggest doing this but it is an option. The problem is doing this can cause instability problems. It doesn't always happen but the chance of a problem isn't exactly in your favor. It's better to match the speed if you can, or bite the bullet and buy all new memory modules. With that out of the way, here's the guide to install the memory in the system.
这个答案有帮助吗?
得分 0
1条评论:
Thanks a lot. So the "matching" means having modules of the same size only?
完成的
添加一条评论
最有帮助的答案
Here is a link to an article on properly matching ram. Good luck.
http://guides.macrumors.com/Understandin...
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
josecelaya 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 10
总计 1,603
