跳转到主内容
加入维修社区 - 创建账户
HTC One Mini 2 于 2014 年 5 月在欧洲、中东和亚洲发布。HTC One Mini 2 的型号为 M8MINx,配备单枚后置摄像头和 16 GB 存储空间。HTC One Mini 2 在外观上与 HTC One M8 非常相似,但体积更小,价格也更低。
Motherboard replacing from EE to O2
As in topic.
I changed motherboard in my HTC One Mini 2... and rear camera stop to working. Front camera works fine. Originally motherboard and phone was EE, now motherboard is from O2. Because motherboard was O2 I must unlock phone, I did it.
After unlocking rear camera sometimes was working, and on second day after motherboard replacing, completly stops to work.
After motherboard changing everything works fine except rear camera...
Any suggestions...?
Update (02/23/2017)
Hello,
I fixed problem with silver colored tapes. This is not a solution...
I think back cover cause problems with camera. Nothing else, just back cover. Camera works without back cover! I try find solution.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Hello,
I fixed the problem. Ribbon cable connector located at the bottom of the upper circuit board caused the problem. I changed it and now everything works fine. Step 13 "Battery" at HTC One Mini 2 电池更换 middle picture at that step.
这个答案有帮助吗?
得分 0
添加一条评论
Check the camera has a good connection to the motherboard or maybe buy a new camera and see if that fixes it
这个答案有帮助吗?
得分 0
添加一条评论
Thanx for your reply. I force stopped camera and then I cleared data and cache and for a couple of times it starts to work... but just for a couple of times...
About your suggestion: camera has a good connection to the printed circuit board (PCB) above motherboard and once I replaced camera, but without success, does not work...
But... when I have been changing motherboard I did not or not seal properly three woven, silver colored tapes to the motherboard and one silver tape by mistake I cutted...
Do you think, there an important woven, silver colored tapes...
Thanx for your reply!!!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Piotr 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 23
总计 337
