跳转到主内容
加入维修社区 - 创建账户
Anova Precision Cooker 蓝牙 WiFi 版是一款旨在利用低温慢煮(sous vide,发音为“sue-veed”)技术将食物烹饪至精确温度的设备。
Anova heating doesn't work
My unit (Anova PC 1.0 BT) does not heat water, but the circulating system still work. The command pannel work, I set the temperature, the water circulates, but the Anova does not heat.
I disassemby the unit, but the fuse seems to be in good conditions (no burn glass, no broken filament). I tried to connect the two parts of the fuse with an aluminum foil, and it doesn't heat.
What do you suggest? I don't think that could be the fuse, but I don't know how to put my hands.
Thank you so much.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
Hello, I don't own an Anova, but I have made my own immersion circulator. If I may advise you, do NOT try to bypass the fuse with aluminum foil as it doesn't handle the high amperage the heating element uses and may burst in flames.
You can test the unit safe and easy using a cheap portable multimeter (If you live in the US, I bet you can get an inexpensive one in almost any hardware store). Just configure it to measure resistance (the guy that sells you the multimeter will show you how if you ask) and test both contacts of the fuse. It shall show you almost no resistance, meaning it's ok. Then test the heating element the same way. It shall be low, only a couple hundred ohms at most. If any of these is burnt it will show very large or infinite resistance.
If both are ok, it can be almost any other part, from the circuitry to the heat sensors, but most the third most probable suspect would be the triac (the 3 leged chip with black heatsink). I can't help more cause here where I live these are too expensive for what they do....
Hope this helps you.
这个答案有帮助吗?
得分 0
添加一条评论
The Triacs are BTA16-800B and BTA26-800B
Mine also had no Heat.. On mine the BTA26 Is Open.
Waiting on one from china. Sorry For the Poor Photos the print on both are were hard to read only have an Older Aven Carton SPZ-50 Stereo Microscope and no Camera on it.
Some of Of My Lab Equipment..
Regards,
Steven
http://www.stevenrhine.com
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lorenzo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 41
总计 4,474
