跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
Phone in water for 2 hrs, good for parts?
This is my first post. If I'm failing to follow any rules, holler. Want to get off on the right foot!
Howdy all. Daughter's 6s submerged in water for 2 hrs. All that has been done to recover it is it was put in a bag of rice for several days. No help there. Would a phone in this condition be worth anything for parts?
I have replaced a few batteries in iphones and I do have the pictured tool kit. Do you experts think I could salvage any dollars for this phone by parting it out? Of course I have no way of testing the parts which I expect will be a problem.
I also have an iPhone 5 in the same condition.
MANY THANKS.
Topside
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
In case you didn't know that rice doesn't help at all with electronics liquid damage:
A video that explains how rice does not help at all (https://youtu.be/yPeITOz2_YM)
Also welcome to iFixit.
The question is how long has it been since after it was submerged for two hours from now?
The longer it's left and if it was left plugged in charge will cause more damage and may result in a unrepairable phone.
Honestly it's probably not worth for parts once the components inside the phone get corroded.
You will have to open up and check if it is.
The iFixit user jayeff should have a guide on what to do to fix a liquid damaged phone.
这个答案有帮助吗?
得分 5
添加一条评论
RWilliams , You can give it a try! Use the guides from the links below 1st link is a tear down guide to enable you to take the phone apart and 2nd link is a general guide on cleaning the phone of water damage/corrosion. Good luck.
iPhone 6s拆解
Electronics Water Damage
这个答案有帮助吗?
得分 3
添加一条评论
If you can't test the parts then your best bet would be to stick it on eBay. Lots of water damaged phones there.
这个答案有帮助吗?
得分 2
2条评论:
If I put it on eBay and a buyer some how gets it to power up, would my data be at risk or would the password protection keep my data safe? Thanks...
完成的
If your screen is locked then they won't be able to access user data on the phone unless they are either Apple, the guy from the University that cracked passcode lock or the FBI.
完成的
添加一条评论
添加你的答案
RWilliams 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 113
