跳转到主内容
Released online on January 16, 2009, the Inspiron 1545 is a 15.6" budget PC laptop available with 3 or 4 GB of RAM. It succeeded the Inspiron 1525.
64 个问题 查看全部
My daughter spilled coffee on keyboard
So my daughter spilled about 1/4 cup of coffee on my keyboard. While on panic mode trying to clean up the keyboard I accidentally unplugged the ac power cord. It does not have the battery since at home I usually use my laptop on the ac power. I worried more about the keyboard and cleaning so it "wouldn't absorb" that I didn't turn upside down right away. Nor did I bother to look up online on my phone to see what to do. When I thought I had cleaned keyboard I plugged in the ac power thinking problem was solved, as soon as I plugged it in their was a loud beeping sound. Dumb me, I decided to press power button off and then on again. I did this about 2 times and then decided to unplug power cord. When I noticed their was some coffee coming out from under laptop. Not a lot, but some drops here and there. Does this mean my laptop is done or is there still some hope???
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
@yesenia_s ,Yesenia S. There is always hope! Do not try to power up the device any more, you may have already caused a short by doing so, you have to dismantled and clean liquid damage. Use the first link below, a guide to tear down your device and the second link is a general guide on how to clean up liquid damage/corrosion. The better job you do at cleaning the device, better odds of getting it up and running. Good luck.
Dell Inspiron 1545 Motherboard Replacement
Electronics Water Damage
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Yesenia S. 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 7,599
