Is it possible to add a lens to my camera?
Please help!? I have a Nikon b500 & i was hoping to add a lens to my camera is it possible if so please let me know thank you
No, this is not a removable lens camera.
这个答案有帮助吗?
Very true!
But, you could add a secondary lens using an adapter tube like this: Adapter Tube & Wide Angle Conversion Lens
Nikon B500+ 2,2x Raynox teleconverter and 3x Sevenoak viewfinder. Its make 88x optical zoom. I can take full zoom pics with out tripod.
这个答案有帮助吗?
过去 24 小时: 6
过去 7 天: 12
过去 30 天: 41
总计 4,654
4条评论
Indeed the camera have a tread is 47.7mm you will see a ring with 3 square holes in the front of the lens, you need a special tool or somethin that can grab 2 or 3 of the holes and carefully remove it by turning the ring counterclockwise. Even so I think will be hard to find the right filter and also you'll need an small extension ring because if you put a filter will touch the lens and it cannot get to the tread and as you can imagine that tread is not to attach a filter.
由 eportillo5000 完成的
Yes it is possible to add a lens to the Nikon b500. There is an adapter you can add. I also added a Raynox 150 macro. Now the macro videos are great. Here's an example of a macro insect video.
https://youtu.be/w-mwDwHPmOc
由 Patricia A Michaels 完成的
do you know what the adapter is called or where to get it?
由 Morgan 完成的
thanks for asking....you can google "B500 lens adapter" and find one on ebay and amazon on the first page. :)
