跳转到主内容
The Nikon COOLPIX B500 is a mid-tier superzoom point and shoot camera. It is sold in black, purple, and red.
Is it possible to add a lens to my camera?
Please help!? I have a Nikon b500 & i was hoping to add a lens to my camera is it possible if so please let me know thank you
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
Indeed the camera have a tread is 47.7mm you will see a ring with 3 square holes in the front of the lens, you need a special tool or somethin that can grab 2 or 3 of the holes and carefully remove it by turning the ring counterclockwise. Even so I think will be hard to find the right filter and also you'll need an small extension ring because if you put a filter will touch the lens and it cannot get to the tread and as you can imagine that tread is not to attach a filter.
完成的
Yes it is possible to add a lens to the Nikon b500. There is an adapter you can add. I also added a Raynox 150 macro. Now the macro videos are great. Here's an example of a macro insect video.
https://youtu.be/w-mwDwHPmOc
完成的
do you know what the adapter is called or where to get it?
完成的
thanks for asking....you can google "B500 lens adapter" and find one on ebay and amazon on the first page. :)
完成的
添加一条评论
2个答案
已选择的解决方案
No, this is not a removable lens camera.
这个答案有帮助吗?
得分 1
1条评论:
Very true!
But, you could add a secondary lens using an adapter tube like this: Adapter Tube & Wide Angle Conversion Lens
完成的
添加一条评论
Nikon B500+ 2,2x Raynox teleconverter and 3x Sevenoak viewfinder. Its make 88x optical zoom. I can take full zoom pics with out tripod.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
pikachu_661 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 28
总计 5,132
