跳转到主内容
Why would the drivers side heated seat not work?
The drivers side heated seat does not work but the passenger side heated seat does work, any ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
Try replacing the fuse.
The seat fuse should be in the Center Instrument Panel Utility Block The center instrument panel utility block is located
underneath the instrument panel, to the left of the
steering column. The seat fuse will be labeled HTD ST
There should be a couple of spares in the box. Check for the correct amperage.
这个答案有帮助吗?
得分 2
添加一条评论
Check the fuse.
这个答案有帮助吗?
得分 1
添加一条评论
Some cars, Buick for example, have separate control modules for each front seat. It's an easy check for your dealer to perform.
这个答案有帮助吗?
得分 1
3条评论:
DEALER? "We don't need no stinkin' dealers."
完成的
Here's the reference for those who don't understand: http://www.youtube.com/watch?v=VqomZQMZQ...
完成的
添加一条评论
添加你的答案
meyersteve 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 12
总计 5,513
