Why would the drivers side heated seat not work?
The drivers side heated seat does not work but the passenger side heated seat does work, any ideas?
Try replacing the fuse.
The seat fuse should be in the Center Instrument Panel Utility Block The center instrument panel utility block is located
underneath the instrument panel, to the left of the
steering column. The seat fuse will be labeled HTD ST
There should be a couple of spares in the box. Check for the correct amperage.
这个答案有帮助吗?
Some cars, Buick for example, have separate control modules for each front seat. It's an easy check for your dealer to perform.
这个答案有帮助吗?
DEALER? "We don't need no stinkin' dealers."
Here's the reference for those who don't understand: http://www.youtube.com/watch?v=VqomZQMZQ...
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 11
总计 5,512
