跳转到主内容
Not enough disk space? Need a backup solution? External drives provide you with extra storage in your office or on the go. Learn how to repair them here.
Accuracy in power adapter to harddrive 0.05A difference
I opened an external harddrive.
The drive inside had
5VDC - 0.7A
12VDC - 0.5A
The drive I want to replace it with has:
5VDC - 0.60A
12VDC - 0.45A
Can I replace the drive without any problem or will it break down due to the extra Amp pushed into it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@junounchanged you are fine with that drive. The difference that small in amperage is negligible.
这个答案有帮助吗?
得分 1
1条评论:
Hi, To add to OT03's answer, as long as the voltage is the same the device will only draw the current that it needs. The only way to get more current to flow is to increase the voltage supply. (Ohm's Law)
完成的
添加一条评论
添加你的答案
hlundstedt 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 84
