跳转到主内容
Nintendo DSi 是 Nintendo DS 产品线的第三款迭代机型,于2008年底在日本市场发布。
How to change the chip NAND
My nintendo fell to the ground, and because of that it does not work properly, but, the console gives life signals when you connect it to the mains. So I decided to buy another nintendo dsi (that was the model that fell me) to be able to remove this console NAND chip and replace it with my old nintendo. Someone could help me.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
What makes you believe its an issue with the NAND?
完成的
No, the problem is not the chip, but I want to change the NAND chip from my old console to another console
完成的
添加一条评论
1个答案
已选择的解决方案
Have you looked at the tear down guide if you exchange the whole logic board from Step 16 that should be easy to do. But if you want to get the Nand chip of then you would need special solder ecuipment to do it.
任天堂DSi 拆解
这个答案有帮助吗?
得分 0
1条评论:
Actually, a full NAND chip replacement is impossible due to the per-console encryption applied to it. You would have to transplant not only the NAND, but also the CPU.
完成的
添加一条评论
添加你的答案
[deleted] 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 11
过去 30 天: 22
总计 1,476
