跳转到主内容
加入维修社区 - 创建账户
针对第三代 Apple iPad (Wi-Fi 版) 的维修指南、拆解和故障排除信息,存储容量有 16 GB、32 GB 或 64 GB 可选。于 2012 年 3 月发布。型号为 A1416。维修时需要使用加热设备并小心撬开。
Bottom of screen not working
I've changed the screen on my iPad 3 and put a tiny crack in the new one when doing so. If you take the screen out and flip it over, the crack runs through the tiny silver coloured lines running around the edge of the screen just above the home button. Is this why the bottom of my screen will not work now? Or do they have nothing to do with it? I've tried to clean out the terminals where the tape connects in but that hasn't done anything.
It's literally the bottom half inch that doesn't work.
All help is much appreciated
Thanks
Dru
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
If the crack is on the digitizer layer and not the black glass then yes you will need to replace the digitizer again.
由完成的
添加一条评论
1个答案
已选择的解决方案
Hi,
Yes, this damage will cause the touch to stop working, or if you have damaged the cable by crushing it etc.
Get a replacement digitiser, and make sure none of the corners or side walls are dented, otherwise your new digitiser will always crack, due to the fact it doesn't fit correctly. :-)
这个答案有帮助吗?
得分 3
2条评论:
That's what it is!! The case is dented from where it has been dropped. I think I need to bend it out a little more in order for the screen to fit correctly. That must have caused the crack when I was replacing it.
Thanks a lot, really helpful!!
由完成的
Not a problem! Glad I could help :-)
由完成的
添加一条评论
添加你的答案
Dru 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 15
总计 73,362
