跳转到主内容
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
1185 个问题 查看全部
Replace screen assembly MacBook Pro retina 13" Early 2015
Hi All,
Sorry if the questions has been asked already.
I need to replace the full screen assemble of my mcbook pro retina 13" early 2015 A1502 EMC 2835.
Have been told that the EMC doesn't matter and that I can replace it with any A1502 as they are the same 2013 onwards.
Is that true?
Many thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
I don't know if this will help or not, but
MacBook Pro (13英寸, 带有Retina显示屏, 2015早期) 显示组件更换
MacBook Pro 13" Retina (Early 2015) Display Assembly
MacBook Pro 13" Retina (Early 2015) Display Assembly图片
产品
$449.99
这个答案有帮助吗?
得分 5
2条评论:
You need Apple part# :
661-02360
Earlier 2013 displays will not work.
完成的
Ifixit says it's for that model. Is it a problem with their listing?
完成的
添加一条评论
The EMC number needs to be the same in order for the top panel to function properly (backlight, webcam, ect.) For a 13" 2015 Macbook Pro the PART number of the top panel you will need is 661-02360. Search for this when purchasing your top panel and you will be fine. Best of luck!
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
FloLDN 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 4,188
