跳转到主内容
Lenovo Essential G560. This laptop has a 15.6" screen, along with a full keyboard with number pad.
How To Fix Loose Charging Port and sometimes '0% plugged in,charging'?
Hi, I have a Lenovo G560 and it is a bit dodgy. Before discovering that my laptop had a loose charging port, I noticed that sometimes it would charge and sometimes it wouldn't. When it was low there was a red flashing light on the row of 4 lights (from left to right; a power light, a battery light, an internet access light and another light I could not understand). The first time, the battery would leak very fast, then enter a sleep mode (I think). After a while, if it was charging, it would turn back on, but if it wasn't I had to force shut down it (by pressing and holding down the power button). When it turned back on, the laptop showed '0%, plugged in, charging' but it wouldn't charge. For the first time, I shut down then turned on the laptop and then it went back to normal. But on the second time, it started charging after 5-10 minutes, all the way to 100% battery.
Please help me! I only have one laptop and my whole family uses it. I need it for my school education. Please respond ASAP...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
4条评论
Hello guys, thanks for your help, I am so grateful. However, I have another problem: today the same problem as in my first comment but it has not charged fully, it's still at 0% battery and the charging cable is very hot near to the charging port and I had to reposition it many times and it's still not working!!???
Also, I have watched the first 2 videos L Pfaff had linked and it was done by professionals. I don't think I can do this and they were both American companies. Do you think it would be better to send it to repair or to buy a new laptop? Help I don't know what to do??!?!! :/
完成的
Just to update I have discovered it is charging, but I cannot go on everyday like this; I have lots of homework to complete. Please can someone answer ASAP!
完成的
S Seth, If you really do not want to try repair yourself pop into a (local) computer repair shop and have them take a look and estimate repair, not positive I believe the repair was approx 1 to 1.5 hours to solder in a jack stating price of $69 in 1st vid, and $100 w/shipping in 2nd, parts and labor. The 3rd link shows the jack assy. which would not need soldered as it includes the wires and plug already attached to the jack and would make it an easy install for you to try. Good luck.
完成的
For some reason unknown to me, today my laptop is functioning fine just like any other day! This may happen tomorrow and thanks for all the support L Pfaff! Will give an update tomorrow.
完成的
添加一条评论
3个答案
已选择的解决方案
Thank you to everyone, however I have found out the real solution. After replacing the power jack, my Lenovo was still not charging. After researching a little, I found out that my charger could be in need of replacement. So I bought a multi-meter/volt-meter and tested its voltage - it was meant to have an output of 20V but it outputted 0.2V. Then I bought a new charger and it worked!
Thanks all once again!
这个答案有帮助吗?
得分 3
添加一条评论
最有帮助的答案
@sseth , S Seth , Use the 1st and 2nd links below to see how to repair/replace the power Jack in your laptop. 3rd link is a replacement power jack which you can also do a search for to possibly get better pricing. Good luck.
https://www.youtube.com/watch?v=JOQiACnI...
https://www.youtube.com/watch?v=TNf-l_5k...
https://www.amazon.com/Eathtek-LENOVO-ID...
这个答案有帮助吗?
得分 4
3条评论:
Thanks L Pfaff, I will try these links and let you know. Thank you so much!!! I hope it works. <3
完成的
Thanks, I will try repairing it.
完成的
i have also same issue, but now solved.
完成的
添加一条评论
sounds like a classic case of you need to replace the charging port.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
S Seth 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 26
总计 51,147
