跳转到主内容
型号 A1136 / 30, 60, 或 80 GB 硬盘 / 黑色或白色塑料面板
Problems with screen in iPod 30GB
I have a 30gb ipod with some problem but i don´t know if is a problem with the screen or with the graphic control. The screen is sometimes operative (i can use the ipod normaly) but in other times the screen shows bars crossing and is impossible to use then machine.
¿ideas?.
Thank you.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
I would go the pass of least resistance and money. Check the connection of the ribbon cable to the circuit board, make sure it is seated properly. Also make sure that the battery does not exert any pressure on the display from the back. If that checks out I would plan on replacing the display. Luckily it is the cheaper part. If that should still not fix it I'd go with the main board. Do you have access to another ipod that you could use to test your display before replacing? Hope this helps.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
jose 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,773
