跳转到主内容
加入维修社区 - 创建账户
KitchenAid Blender 5KSB52 Ultra Power 在设备的多处印有“KitchenAid”字样,包括盖板和底座。
My blender makes noises
my blended has stsrted making noises . By trying the the jar with another blender I found out that the noises dont come from the motor unit but from the blades unit . The blades are well tightened and aren't deformed . There is a drop or two leak during every time I use it.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
What kind of noises is it making? If it is making knocking noises, I would check the blades first to make sure they are tight and not wobbly. I would also check to make sure none of the contact points, where the blade connects to the motor, to make sure none of the points were worn down or broken off. A whirring noise might indicate motor trouble, or blade issues if the blades are binding up because of a bad bearing or just rust.
由完成的
添加一条评论
2个答案
已选择的解决方案
i'd like to replace the 2 small rubber seals of the blades assy . is it possible ?
这个答案有帮助吗?
得分 1
1条评论:
From the parts diagram I found searching the model 5KSB52, I can only see one replaceable rubber seal, and it's the one that seals the blade assembly to the pitcher to prevent leaks. I put a link below to that page, but if you search "5KSB52 parts", there are a few places that have parts and diagrams. If there are rubber seals under the blade, and it looks like there might be, they are probably just o-rings. You would probably have to disassemble the blade, if possible, and either measure them, or take them with you to the hardware store, or motor parts store to find a suitable replacement. Just be careful disassembling the blade assembly if you try.
http://www.partselect.com/Models/5KSB52-...
由完成的
添加一条评论
最有帮助的答案
If it is leaking, then it is either a worn out bearing surface in the blade assembly, a bad rubber seal that is allowing movement of the blade assembly, or a loose collar. I can't find any parts for the blade assembly, apart from the entire assembly itself, so I doubt they made that serviceable. If your rubber seal is good, then I would replace the blade assembly.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
solo246 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 25
总计 6,448
