跳转到主内容
加入维修社区 - 创建账户
Sony Xperia Z3 是一款 2014 年发布的 Android 智能手机,以其出色的电池续航时间和耐用性而闻名。
SIM and signal problem
After screen replacement with frame phone works fine, BUT when i insert SIM it doesnt recognize it...it takes few minutes to ask for PIN.
After i enter PIN there is no service and no signal...i cant even turn off 4G etc.
I tried to put back old screen with frame, that has broken touchscreen but problem still there. i changed antena cable, and every other part inside.
SIM reader looks fine.
i tried factory reset, and software repair with xperia companion
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
8条评论
check network filter my it gone
由完成的
Hi, does it say no sim, or no service?
由完成的
first it says no sim...then after few minutes it ask for PIN and then there is no service annd no signal...i tried different sim cards
由完成的
Anybody can me at least some tips what could i try?
由完成的
Not registering the sim. Try getting a new sim card. It is possible that that card was damaged.
由完成的
显示更多的3条评论
添加一条评论
2个答案
已选择的解决方案
Well I can say at least the antennae is not causing the issue as you have already replaced that.
Does it display an IMEI number under the phone settings > general > status (something like this)? If there is no IMEI number then you have pretty much a phone that is no good for sim card usage and probably better off getting another phone if it's yours.
I'll just relist these even if they have been mentioned already:
Not detected sim card:
- Bad sim card (Could be just faulty, dirty, physically won't fit or line up with the pins properly)
- Sim card reader could be damaged, either on the housing of the reader that wont let the sim sit on the connection pins properly, misaligned or missing pins.
- Incorrect sim card tray being used if this sony xperia model uses it. (Could also be upside down, wrong way orientation of tray or sim card etc).
- Very highly unlikely but maybe network locked phone. Was it working before you did the screen replacement?
While I have done a few of Sony Xperia Z3 screen replacements in the past LCD only and LCD with frame I find it hard to manage to get the sim card to not read properly after that.
The logic board has the sim card reader on it, maybe it's an alignment issue with the board being installed not lining up with the housing properly? Usually this never happens, you have all of the board screw and antennae covers on the logic board clipped on right?
The bottom part of the phone also has housing that should be clipped and tucked in properly to gaurantee the antennas are contacting properly with the covers. Also the LCD cable from the screen needs to tuck in properly with the metal cover on top of it. Also make sure the metal midframe is not unclipped pushing either side the board / battery or LCD. There are like 3 clips for the metal to the housing frame on each side (excludes top and bottom).
Honestly IMO sony xperias are just as hard as doing HTC One M8/M9 screen replacements. Too many things can go wrong easily and you need to make sure everything is aligned, put in place, clipped in properly which is why I stopped doing screen replacements on HTC and Sony xperia in general. I still do Samsung from time to time but rarely even though it's easier to repair IMO.
My sony repair history
- Broken mic flex, did not install antenna cover properly causing no signal issue on 3G / 4G.
- LCD getting damaged on improperly installation / lifting up LCD
- Breaking antenna cable or on logic board side (though you can avoid this easily of course by just pulling up the antenna cable from pulling cable instead of unclipping it with a nail from the end which will most likely break the antenna connector off the logic board.
这个答案有帮助吗?
得分 3
添加一条评论
Change main strip.it causes no network no sim
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
PS15 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 20
总计 13,552
