跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Why does my iPhone 6 turn off when I open apps
Okay, so my IPhones battery has been swelling in one spot and I ordered a new one and its on its way. But I have my phone plugged into the charger and it works just fine( as long as its plugged in) as soon as I take it off the charger and I try to go into an app or even if its just sitting there it says it "dies" and won't turn back on and is on the dead and need to be plugged in black screen. And as soon as I plug it back in it takes a second but the Apple sign comes up and says its at 100% but once I take it off and try to do something it does it again. Please any help
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
@travisc you would want to stop using your phone altogether. If you still have your swollen battery connected, plugging your phone in will still try to attempt to charge that battery. You are going to damage your phone more by continuing to use it.
Rep: 1
完成的
添加一条评论
3个答案
已选择的解决方案
You do need a new battery. But why are you asking if it crashes when you open apps? In your post you said if you take it off the charger, and it dies.
You said you ordered a battery, but just in case
Labor, in case you have any questions
更换你的iPhone 6电池
iPhone 6 Battery
iPhone 6 Battery图片
产品
iPhone 6 Battery
$29.99
这个答案有帮助吗?
得分 2
添加一条评论
hi travis carpebter
its battery problem you need to replace the battery it will work fine....
iphone batterys comes 600 cycles may be you reached more than that if you replace new battery it will work.
this is the link for battery replacement guide
这个答案有帮助吗?
得分 0
添加一条评论
Guaranteed your battery is dead. As soon as you swap the new one in it should fix this.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Travis Carpenter 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 2,183
