跳转到主内容
加入维修社区 - 创建账户
这是iPad mini 3(型号A1599)Wi-Fi版本的维修指南。这款iPad在2014年10月16号作为iPad Mini Retina屏版本(现在也称作iPad mini 2)的新一代被发布。
screen is getting self commands without touching it
after changing the ipad screen in a workshop, the screen is working and powering normally, but it keeps getting self commands without touching it. any suggestions, is it the LCD or digitizer problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
6条评论
Do you mean it the home button acts as if it were pressing itself?
完成的
hi Stephen, not exactly! its like several applications are opening , same like if you are swiping the screen and selecting applications. in a mean that the screen is getting touch commands by itself. thanks!
完成的
thanks again Stephen, I totally understand you. I believe that they did not use an original/OEM Digitizer for replacement, or they did not fix it properly. I will replace again myself. just one more question: do you have idea whether the thin black cloth comes with the new digitizer if I order it from ifix it.
完成的
Absolutely bud its no problem at all. I'm honestly not sure. I can vouch ifixit has quality parts but not sure about original parts. I would double check with them before ordering. You basically want to get one that looks like this picture if possible. The cloth strip is covered in blue peel off in the picture. Also if you chose to do it yourself please, and I can't stress this enough, please disconnect the battery before disconnecting the lcd and the digitizer connector or you could blow a fuse. Its a very simple fix for a micro solderer but if you don't know the motherboard it can be a pain.
https://www.google.com/search?q=original...
完成的
thanks 4 ur help dear. will check with them prior to buy.
完成的
显示更多的1条评论
添加一条评论
1个答案
最有帮助的答案
Hey, gotcha. That's actually very common with the iPad mini digitizer replacement. So that would actually have nothing to do w/ the lcd. If its ever a problem w/ touch on your device it will be related to digitizer and any problems related to picture is lcd.
Most likely one of two things is going on. Either your replacement screen is faulty or your replacement screen didn't come with the protective cloth tape strip at the bottom. If you still have the original screen and look at the bottom inside of it, near the home button hole, you should see a thin black cloth like strip that goes along the width of the glass itself. This helps against what's called "ghosting" which is what you're experiencing. Its kind of weird to explain so hopefully that makes sense. If not or if you have any other questions don't hesitate to ask
这个答案有帮助吗?
得分 3
1条评论:
Is screen flickering caused by the same issue?
完成的
添加一条评论
添加你的答案
Rodny Soueidy 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 21
总计 623
