跳转到主内容
加入维修社区 - 创建账户
DJI Phantom 系列的第三代产品,于 2015 年 4 月发布。
cannot start my phantom 3 standard anymore
when I was 2 ft of the ground to take off, one motor quit working causing the drone to crash but no physical damage was done.
Now nothing seems to work anymore, I can't start the unit, does not even make sounds or any led's are working, I did try another new battery but with the same results, I really wish it would start again, the unit is only 3 weeks old with about one hour of flight time on it.
If anyone knows what to do to get it working again, please respond, I would really appreciate it.
Fred
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
Dude i kinda had that problem i crashed my drone but then when i turn it on it flashes and everything but when i click takeoff nothing happens dosent even move the propellers
由完成的
添加一条评论
1个答案
Hopefully you can return it under warranty since it’s not too old. Otherwise you would need to disassemble and check the power connections and see if any other part looks cracked or disconnected. Once you open it, you will likely void any warranty, so try that route first.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
fredpeers2004 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 19
总计 617
