跳转到主内容
加入维修社区 - 创建账户
How to replace battery?
I've read that the battery is not replaceable, but I wonder if someone has managed to replace it somehow and if so, how, and which replacements were used?
(Not yet needing it, but would be nice to know for the future)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 8
1条评论
Just because I like to put up and not throw everything away...
Attila
由完成的 分享
添加一条评论
5个答案
最有帮助的答案
http://ilovebigmac.tistory.com/entry/Pla...
I find it, But it is only Korean
If u want, you can read by Google Translation.
这个答案有帮助吗?
得分 4
3条评论:
Hi,
This is for the 'earbuds' not for the bigger ones that are external to ear.
Thanks however!
由完成的 分享
Hi and thanks for sharing this. I am trying to replace the battery as well since my Backbeat Go 2 won't charge anymore (light stays red). Can you please tell where have you found the battery?
由完成的 分享
Thanks for the link. Google translate was enough to get me what I needed. Found the battery in a few places, surgery next month!
I am glad your answer was what I needed, sorry it was not what OP needed.
由完成的 分享
添加一条评论
https://www.youtube.com/watch?v=fpfpfutF...
这个答案有帮助吗?
得分 2
添加一条评论
I have a backbeat pro 2 headset since 3 or 4 years and the battery recently died, I can't reload it anymore, the charging led remain red even if I let it charge several hours.
I dismanteled the headset and I saw the battery is on the left side. The battery is soldered to the PCB so if you want to change it you need a soldier iron.
The characteristics of the battery are: 5cm long and 3mm wide, 650mAh, 3,7V.
I think you can find similar batteries on internet but non official. I will try to change it mine soon, hope I will have no problem with a chinese battery.
这个答案有帮助吗?
得分 2
3条评论:
Any progress here Michael?
Does the battery have any serial # on it?
由完成的 分享
Hello, some news about changing the battery on a backbeat pro 2.
I finally bought this battery:
https://a.aliexpress.com/_vncLLJ
Unfortunatly it is a bit to wide so i can't tighten the screws to the maximum. It's not perfect but it is acceptable.
I tighten the screws the maximum I could, so now I can't control the volume directly on the headseat. It's the only negative point.
No problem with the battery, I can now use my headset several days before listenning the "battery medium" sound.
I recommand to find a battery a little bit less wide.
由完成的 分享
There are a few I'm looking at. The original 3mm you measured sounds like the height. The one on aliexpress is 8mm. Found one on Amazon at L 50mm, W 22mm, H 7mm. Probably still not thin enough too fit? https://www.amazon.ca/gp/product/B07TXJ8... And, just to be clear, we're talking about the Backbeat Pro 2 with the elliptical shaped ear pads, right?
由完成的 分享
添加一条评论
sorry but your answer is for the backbeat go, not for the back beat pro
这个答案有帮助吗?
得分 1
添加一条评论
I came across this video showing how to replace the battery in the Plantronics BackBeat https://www.youtube.com/watch?v=fpfpfutF...
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Pablo Iranzo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 49
总计 14,967
