跳转到主内容
加入维修社区 - 创建账户
于2015年10月26日上市的第四代Surface Pro平板电脑。
Source A Replacement WiFi Antenna?
Hi everyone,
I am in the process of doing my first screen replacement on a Surface Pro 4
I've got the screen off and disconnected all the cables without an issue following the guide here but I accidentally snapped one of the WiFi antennas during the screen removal.
The only website I can find for the part is :-
http://www.powerbookmedic.com/Microsoft-...
However they are out of stock
Anybody know another place I can get one? Tried searching for the part number (X939878) online but that's the only useful website that comes up.
Help!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
11条评论
What is the length and does it have mini coaxial connectors at the ends? You should take a good picture of it and especially the connector.
由完成的
Any good news. Have same issue
由完成的
I have the same issue,. Screen crack made it nearly impossible to remove without damaging. Did either of you try without. Was wondering if it just wont work or the signal levels will just drop?
由完成的
I'm waiting on my replacement screen and then i'll put it all back together and check.
I'm HOPING that i'll be lucky on this one as I still have 1 complete antenna and 70% of the second one, I've only broken about a third of the connector!
I'll update here when my new screen arrives!
由完成的
I had a extremely frustrating call with Microsoft today. After being passed around more than a joint in 70's. They tell me they do NOT sell internal replacement parts to customers or professionals. Rep said they consider opening the device tampering anyway. What a joke! I also contacted Power Medic and the rep said they haven't had the part in stock for months and don't plan on getting it in anytime soon.
由完成的
显示更多的6条评论
添加一条评论
6个答案
已选择的解决方案
I reconstructed the destroyed antenna out of aluminum foil and double-sided tape.
I have no idea if it's actually working, but I like to think so. ;-)
Details on my blog:
https://blog.kamens.us/2017/05/10/lesson...
这个答案有帮助吗?
得分 1
4条评论:
Your awesome!!
由完成的
Hi. I've just done this fix on my antennae where I had to replace all 3 of them due to a very smashed up screen. My Wi-Fi, Bluetooth all works great. Top bloke! Can not thank you enough. I have taken a photo to show all 3 but not sure how to put it on here lol
由完成的
Awesome idea. I wanted to use double sided tape also but then I remembered that there's an aluminum tape which you can get at Home Depot in the A/C section.
由完成的
You can also get it off Amazon for 10 bucks
由完成的
添加一条评论
I used aluminum foil as well and everything seems to be working. Good
这个答案有帮助吗?
得分 1
添加一条评论
I’ve just finished a Surface Pro 4 and the left antenna was destroyed when removing the shards of the original screen.
Its actually fairly straightforward to create a new antenna using copper tape with conducting adhesive.
Remove the antennas unit (4 screws) and cover the area where the broken antenna was and tape round to the underside so the pins on the logic board touch the tape.
I added 4 layers of tape to the section where the pins touch the antenna and also bent the pins up slightly to be sure they’ll cotact the tape.
Wasn’t all that difficult, don’t bother looking for a replacement antenna, this will be much quicker.
这个答案有帮助吗?
得分 1
添加一条评论
But before you do such a recknack solution also take a look on Alixpress. Found there a few of good products and you could buy these antennes for all the different models. Just type in “surface pro antenna” and you will have a couple of recommodations.
这个答案有帮助吗?
得分 1
添加一条评论
I'm in the same boat. Replaced the cracked screen on my SP4 and shredded the antenna getting the old screen off. Basically nothing left on either side of the top of the antenna bar - just the contacts on the bottom. I've been using the SP4 with the new screen taped in place, hoping I can find an antenna before sealing it up. WiFi and Bluetooth both seem to be working fine; I don't know how to check signal strength...
Main lesson I've learned is that I wish I had bought the MSoft warranty with the SP4. Having lived with the SP4 for only a couple months, I feel that the warranty is a pretty good value.
这个答案有帮助吗?
得分 0
添加一条评论
https://www.amazon.com/Deal4GO-WLAN-Wire...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Alex S 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 24
过去 30 天: 66
总计 14,342
