跳转到主内容
加入维修社区 - 创建账户
由 Azend/Envizen 制造的平板电脑的维修指南和支持。
SIMM card inside the tablet
The small inter part of the SIMM card broke off in the slot. What can I do to get it out?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
It's hard to say without being able to see it. I usually utilize a pick (VERY CAREFULLY) to try to pull the card out. Is it visible enough for you to take a picture?
-CW
这个答案有帮助吗?
得分 1
3条评论:
Thank you so much for the information but the small card is not visible. You need a small flashlight because it at the bottom. The Geek Guy said he would need to take the back off.
由完成的
Without a solution, I took it to the Geek Guys. They took off the back and took out the card. What a rip off. $20 to take off the back and investigate the problem then another $20 to remove the card. I will try to solve the problem myself next time with a pick.
由完成的
If you do, just make sure that once again, you are extremely careful.
由完成的
添加一条评论
添加你的答案
Jtourre 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 24
总计 604
