跳转到主内容
I think my phone is bent
I tripped and my phone was in my hand, since then I have been thinking that the fall bent my phone. I replaced my screen protector and the new one has gotten a decent bubble coming up the side of the phone and at the top. I have put the phone screen down on a counter top and it wobbles a bit. The phone works perfectly fine otherwise. But I was wondering if there is a way to unbend?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Joe Ziemba, May be best to thank your lucky stars phone is working properly and just possibly a little bent. If you try to bend it back something could possibly break. Just my 2 cents. If it really does bother you, I will post a tear down links of your phone which may be useful, as maybe just the battery is damaged/bent and can be replaced. Good luck.
https://www.youtube.com/watch?v=lhAFtP0F...
Nexus 5X Teardown
这个答案有帮助吗?
得分 2
2条评论:
Thanks for the quick reply, I get that something could break, which is why I posted the question before trying anything. I didn't know if I would be able to easily take everything out of the phone and attempt to bend the frame back...
完成的
Joe Ziemba, Joe the video link in my answer will show the disassembly along with this link, if you would like to try bending it back.
Nexus 5X Teardown
完成的
添加一条评论
添加你的答案
Joe Ziemba 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 4
过去 30 天: 5
总计 949
