after market oil filter and oil cooler
does installing an after market oil filter and oil cooler help the 40 hp bug engine?
@willyt , William, If installing/switching filter/cooler out for good quality/ higher capacity/ more cooling area(fins) and installed correctly, it can benefit your engine, especially in warm climates. Check out the links below to see what they have to say and recommend. Good luck.
https://www.youtube.com/watch?v=MWynxdKo...
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 26
总计 1,780
2条评论
Installing a high quality oil filter and oil cooler will improve HP torque and reduce the probability of overheating of the engine (by cooling the engine oil).
由 S W 完成的
also put a bigger oil pump in to counter act extra resistance in oil cooler and filter
由 dave jackson 完成的
