跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
How to remove bottom torx plus screws on ip4
I get a few iphones off ebay and use the advanced replacement to get some clean refurbished ones to sell. (sometimes i mod them white). Now the screws come with torx plus. i used a T1 screwdriver and that started stripping the screws. Can u tell me how to remove them? i was thinking of using a dremel if all else fails. since i got 4 full white kits and i need to use them.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
7个答案
最有帮助的答案
We usually find a 1.5 mm flathead screwdriver bit (or whatever size is slightly larger than the distance between two lobes furthest apart from one another) and file it down until it fits in there. It's a bit easier to remove the screws if you push down on the screwdriver when you initially break the screws free (takes some preload off the threads).
这个答案有帮助吗?
得分 2
添加一条评论
try find them on ebay.
这个答案有帮助吗?
得分 0
添加一条评论
Looks like very limited availability :) http://www.traderscity.com/board/product...
and http://www.8starshop.com/en/12-in-1-comp...
Check this question has more answers for you Where can I buy one of these pentalobe tools
这个答案有帮助吗?
得分 0
添加一条评论
Here's how I thwart safety screws, though I dunno how well it will work in your situation; the Torx Plus screws on an iPhone are smaller than the screws I've tried this with before
You'll need a hard plastic pen (Like a Bic Cristal) and a source of heat, but preferably not an open flame. Remove the ink cartridge and ballpoint; you're not going to need them for this.
Basically, the idea is to melt the plastic so that it becomes pliable enough to flow into the screw-head, cool, and act as a temporary screw-driver.
If you're going to be working with a particular type of Security Screw often, I recommend tracking down a proper set of drivers for it. But if this is just an exotic screw type that you encounter only so often, this makes a pretty good stopgap solution. I've used it to beat Security Torx, TP3's, and Tri-Wing screws when I encounter them.
The only thing I wouldn't recommend using it on is Spanner (Snake-Eye) screws.
这个答案有帮助吗?
得分 0
添加一条评论
These screws are pentalobe screws, to open it and to put in standard phillips ones, get iFixit's iPhone 4 Liberation Kit.
这个答案有帮助吗?
得分 0
添加一条评论
The correct tool to remove the pentalobe screws is the IP2466 tool. I found this info while sourcing the same question.
这个答案有帮助吗?
得分 0
添加一条评论
what side the tools torx for iphone 4?
Update
The thing is that some iPhone 4's have two phillips type screws on the bottom and the newer ones and those that Apple repairs or opens have TORX screws on the bottom. If you take your phone into Apple and they open it they are replacing the Philips screws with TORX screws. This is an attempt to keep people from opening their phones.
What size philips ?
What size TORX ?
Any good tech will need both types of screwdrivers.
Any good source in the USA to buy these small drivers ?
这个答案有帮助吗?
得分 0
1条评论:
SpudgerToolCom has these screwdrivers on Amazon or eBay.
完成的
添加一条评论
添加你的答案
Tarek Sebak 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 53,371
