跳转到主内容
加入维修社区 - 创建账户
由 Google 和 HTC 共同开发的 8.9 英寸平板电脑。于 2014 年 11 月首次发布,搭载 Android 5.0 Lollipop 操作系统。
Sudden refusal to charge
After a couple of years of 'no problem' day to day' use, my Nexus 9 has suddenly died. I don't think think it was 'mid use death' , it hasn't been dropped etc and is in excellent condition.
I suspect that it ran out of battery and now is refusing to charge. I'm not even getting the white flash when in a very low battery state.
Before I buy a replacement battery, does anyone have any suggestions?
Ive tried every combination of button pressing to boot to different states, bit I suspect it's a batter issue.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
I have no suggestions except replace your battery. I'm pretty sure that your battery is completely dead.
这个答案有帮助吗?
得分 1
4条评论:
Just a quick update, my new battery arrived today, fitted it and booted first time.
完成的
Yay!!! Glad your phone is back to working condition :)
完成的
Phone? The Nexus 9 isn't a phone, it's a tablet. I don't even think it has 3G/4G capabilities. What do you mean?
完成的
David. Just a question. Where did you find a Nexus 9 battery? It is a nightmare to find....
完成的
添加一条评论
最有帮助的答案
@davidtjackson you may want to check that your chargers working . Check your cable try it with another one, check the port that theres no lint or dirt preventing the cable from connecting properly . If you have access to another charger try it . You may also want to reseat the battery as it can sometimes just need to make a new connection to work again and recharge. These are a few things Id try before buying a new battery. Hope this helps
这个答案有帮助吗?
得分 3
添加一条评论
Thanks both,
I've managed to rule out it being a faulty cable. I've found a replacement battery - so hopefully it'll be that. I'd have expected it to last longer than a couple of years, but I suppose these things just die every so often.
这个答案有帮助吗?
得分 0
1条评论:
Glad to help. And sadly yes, rechargeables only have so many charges in their lifetime.
完成的
添加一条评论
添加你的答案
David Jackson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 17
总计 515
