跳转到主内容
Repair guides and support for the laptop/tablet hybrid in the Toshiba Satellite Radius series released in 2014.
48 个问题 查看全部
Screen Replacement for P55w-B5220
Thank you in advance.
I need a replacement for the screen both the lcd and the touch panel., where can i get them.....
looked in ebay and amazon and didnt fine any...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
3个答案
已选择的解决方案
Here you go...
http://www.ebay.com/itm/Toshiba-Satellit...
It may be cheaper to just get a new laptop.
这个答案有帮助吗?
得分 4
2条评论:
Hey bro. Amazon has the entire screen for around 200us. Be very careful when using a flat screen removal tool around the corners of the display where you will see a thin gap. I had to figure it out my self since they weren't any video on YouTube yet
完成的
@gilcom You do realize that AT THE TIME THIS WAS ANSWERED, screens totaled these out right? This is an OLD POST.
完成的
添加一条评论
I have the same issue, here is what i found so far:
http://www.lcds4less.com/toshiba-satelli...
这个答案有帮助吗?
得分 1
1条评论:
Can you give me directions on how to remove the screen for Toshiba Satellite radius p55w-b5220 screen?
完成的
添加一条评论
i have toshiba P55w-B5220 touch screen and its screen changed to pink i check all the cable connected to screen but fail what i have to do please need suggestion.
这个答案有帮助吗?
得分 0
1条评论:
check for screen connection prongs that are bent on not seated fully
完成的
添加一条评论
添加你的答案
Tammam Alzaidi 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 13
总计 7,145
