跳转到主内容
Repair guides and support for your Sanyo TV.
360 个问题 查看全部
When turning on my Sanyo fw65d25t , red led light blinks but no pictu
Sanyo fw65d25t .. when turning on, the LED light will blink about 10 times but no picture will come on. Put a new main board in , no change .. tv was hit with lightning surge that came in Thru the video input .. any advice?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Did you find out what the issue was?
完成的
添加一条评论
1个答案
已选择的解决方案
@xman14
I recognize this is an old question but looks like there are still inquiries. If a new main board did not fix this, I would check the power board and see if you get the backlight enable coming on. Also, check the T-con board fuse and see if it has continuity as well as power.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Ken Exum 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 6
总计 1,322
