跳转到主内容
加入维修社区 - 创建账户
Zeki 制造的平板电脑的维修指南和支持。Zeki 平板电脑的背面中心印有大写字母“Zeki”。
problem with storage/SD card
I have an external SD card, i t won't allow me to add any of my apps. My tablet says storage space is running out, what is going on?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
Hi,
When you go to move the apps, is there an option to do so or is it greyed out, (move to SD Card)?
If there is no option to do so or it is greyed out, it is because the developer of the app has not set the "permission" flag which enables it to be moved. This could either be by omission or design.
Also if the apps that you wish to move came pre-loaded with the tablet, they are part of the system and can only be moved if you root the tablet.
这个答案有帮助吗?
得分 2
2条评论:
There is the option to move to SD card, but when I try to move it ,it reads no storage space. I even tried a new card and got the same results.
由完成的
Hi,
Not sure if you have this setting but go to Settings > Storage and see if the SD card appears as a storage option and how much storage space is available.
Have you tried inserting the card into a card reader connected to a PC and see what is stored on it (if anything)?
If nothing is stored try formatting the card again and then re inserting it into the tablet.
由完成的
添加一条评论
Either it's full of data, or hasn't been properly formatted.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jetherton1949 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 14
总计 1,533
