跳转到主内容
加入维修社区 - 创建账户
BLU TANK II T193 超长续航电池,待机时长可达 30 天 由 BLU 在迈阿密设计 | 在中国组装 www.bluproducts.com
Calls will not go through
When I try to make a call, it shows that it is dialing, but then a "Failed" message comes up.
This is a new problem.
I am also wondering why the phone screen says "Emergency" at the top left corner.
Your suggestions would be very much appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
from the sound of it you are just in an area with really bad reception. try moving to a different location where you have full bars and it says that you have full data connectivity also. sometimes my phone will have bars but if it does not show data connectivity then it will not allow me to make any calls except "emergency only"
hopefully this helps you out and you are dialing away soon
这个答案有帮助吗?
得分 0
3条评论:
Thank you very much for responding. I ended up calling the service provider and , after much trying of this and that, determined that the phone itself is the problem. Oh, well, at least it was not an expensive one.
完成的
that is great to hear. well i hope that by now you are calling away to all your friends lol. good luck in the future
完成的
@carold make sure the phone is reading the sim card
完成的
添加一条评论
Try to take out the SIM card, clean it then re-insert it. Sounds like it isnt recognising it.
这个答案有帮助吗?
得分 0
2条评论:
Turns out the SIM was OK and the phone was bad. I really appreciate all the suggestions I got.
完成的
you are welcome
完成的
添加一条评论
Well, I've done everything I read to set up my Blu Tank II, bought prepaid service from H2O & still getting "no service". Anyone have some insight on what I'm doing wrong?
I called H2O for support, the guy couldn't help me after 15+ mins, said someone would call me back in 10-15 mins, never received that call back. This is getting so frustrating.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Carol Dankelman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 1,399
