跳转到主内容
加入维修社区 - 创建账户
Nikon D5200 是一款采用 F 卡口的单反相机,配备 2410 万像素 DX 格式 CMOS 图像传感器。D5200 的最高分辨率为 6000x4000,并支持 1080p 视频录制。
My camera just died!
I've fully charged my battery and when I try to open it, the green light flashes (as normal) but it doesn't open and when I see in the view finder, it indicates that it hasn't charged and the battery is empty even though I've just fully charged it.
P.S: I've tried another battery and it's the same
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
have you tried using another charger to charge the batteries and checking the voltage levels in the batteries to see if they are actually charged. It could well be that the mains charger is faulty and not charging the batteries properly.
这个答案有帮助吗?
得分 0
2条评论:
I've tried it and it's the same
由完成的 分享
my next advice would be to open the camera up and check the solder joints on the battery contact and motherboard side contacts, sorry there isn't a guide available on how to do this but the D5100 and D5300 are both similar cameras and open up pretty much the same way, so follow the guides on how to open those cameras as best you can.
由完成的 分享
添加一条评论
If restoring camera to its default factory settings will fix this issue then its ok, otherwise visit Nikon D5200 Manual to proceed another solution.
To restoring Nikon D5200 to its factory settings, just hold down the [Menu button] button and the [Information button] button together, until the control panel turns off briefly while the camera resets itself to the factory default settings.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mustafa Hmood 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 16
总计 1,502
