跳转到主内容
加入维修社区 - 创建账户
一款带有耳罩式耳机和可拆卸全向麦克风的游戏耳机。随附 Xbox One 音频适配器和一根 micro USB 更新线。于 2014 年发布。
Jack snapped in two
The jack on my cord to my headset has snapped in two. Can it be fixed? Replaced?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
It looks like the jack is a two-pole stereo jack. This fix will require some soldering.
  1. Find a 3.5mm (AUX) cable of sufficient thickness.
  2. Cut the end off of the headset's cord, and cut off about 3 inches from the end of the AUX cable.
  3. Strip about an inch off of the outside sheath of both cords, then strip about 3/8 inch off of the end of all the ends of all wires inside (there should be 2, plus a sheath or ground), and twist each internal wire so that it doesn't fray. Twist the metal sheath into a third wire.
  4. Slip on three 1.5" pieces of appropriately sized heat shrink tubing onto each wire, and slip on a fourth 2.5" piece over the entire thing.
  5. Match the colors of the wire to the end of the AUX cord, then solder the two together.
  6. Slip the heat shrink tubing that you previously put on over and use a hair dryer, heat gun or lighter to shrink it around.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jceresman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 646
