跳转到主内容
The Gateway NV52 was released in 2008. It is similar to the MS2274 and NV5207u models.
which monitor controller can I use for this laptop
My laptop stopped working, and I'm not interested in fixing it, but I want to use the monitor as a second display for my station, but I need a controller [if I understood correctly], can someone instruct me which controller to get?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
@carrotsy that will depend on your display panel, not your computer. Disassemble your dispaly to the panel and take a look at the label on it. Most common panel for your model is a B156XW04 (there are different version recognized by the V.X number on that label. With that number do a search on either Alibaba.com or ebay.com for a "universal LCD controller board". You should find something like this. Again, always double check your LCD panel. To connect the kit is actually pretty easy. Check this guide for a bit of an idea what you are getting into.
这个答案有帮助吗?
得分 2
2条评论:
I guess I was wrong again.
完成的
@pccheese not wrong you just have not build one yet. You are getting there, reps are looking good.
完成的
添加一条评论
添加你的答案
Salah 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 202
