跳转到主内容
2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
580 个问题 查看全部
Replacing Airport Antenna Cable
I was doing a screen replacement on my Pro and managed to break off the middle antenna connector. My wi-fi still works, but the signal is definitely weaker, and bluetooth is so weak that it only detects devices sitting directly on the keyboard.
I was wondering if anybody had any experience fixing this wire without disassembling the entire display. I was thinking if I stripped it and soldered an antenna connector from another display, it would work fine.
Any ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
3个答案
已选择的解决方案
I ended up cutting part of the antenna cable off from a broken display, stripping both cables, soldering them together, and covering them with some electrical tape. Not the cleanest solution, but definitely the cheapest!! Bluetooth and wifi fully work now.
这个答案有帮助吗?
得分 1
2条评论:
Can I know how you did that? The inner core contains silver wires and the outer part contains a copper wrap and silver mesh shielding. Is it okay for the outer meshes to touch the inner core?
完成的
have picture of it ?
完成的
添加一条评论
最有帮助的答案
Ouch!
Well i've got some good news you don't need to take the display assembly apart only take it off as the antenna unit is within the clutch cover (black plastic between the hinges. Here's the IFIXIT guide to get the display assembly off: MacBook Pro 15" Retina Display Late 2013 Display Assembly Replacement. Then get this part: iSight Webcam WiFi Cable Apple P/N 818-2882. The trick here is to carefully unsolder the antenna lead you need and feed it though the hinge replacing the broken one.
这个答案有帮助吗?
得分 1
3条评论:
It turns out the antenna unit is stamped shut, so it's impossible to access any of the leads without breaking it open. Check my answer for what ended up working.
完成的
FYI - It slides to one end and then pops off (bayonet style).
完成的
No I mean the actual antenna underneath the black shroud. It's stamped shut, so you can't unsolder anything with cracking it open.
完成的
添加一条评论
How did you fix it??
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
illya 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 7
过去 30 天: 18
总计 5,686
