跳转到主内容
The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
20 个问题 查看全部
How old is my machaine
My house came with this machine but I need to sell it and people want to know how old it is, is there any way to tell from the model and ser numbers.
MOD 110. 25132411 SER C61542901
Thank you so much for your help
Amy
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
19条评论
my serial # is 808KWWZ00185 model # is 79648852800
anybody know how old this machine is. kenmore
完成的
What's the stock number , like if its 618-01 then it was made on June 18th 2001. There should be another set of numbers near model and serial numbers
完成的
My Kenmore model 110 has a serial number if CR4242155. Based on other response I can't figure mine out. I bought it used in March 2020. Thx.
完成的
@ofrdrsq881 what is the complete model number? Double check your serial number as well. Kenmore really did not make your washer but it was either made by Whirlpool or by Frigidaire. Both companies use a different numbering system. If your washers model number starts with a 110 then it is a Whirlpool made if it starts with 417 its a Frigidaire
完成的
My Kenmore washer has the serial number c110 526 0080. Does anyone know how old this is?
完成的
显示更多的14条评论
添加一条评论
8个答案
已选择的解决方案
Repair Clinic offers this service.
Go here and enter what information you have:
http://www.appliance411.com/service/date...
The site shows me the following on your machine:
According to the serial number this product may have been manufactured in Clyde, OH, April of 1976 or 1986 or 2016.
Based on the model number supplied, this product design may have been introduced to the marketplace for 2014 in which case the closest date indicated by the serial number may be the actual manufacturing date for this product.
这个答案有帮助吗?
得分 4
添加一条评论
Hi @Edie Nelson ,
I don’t know how accurate this will be but according to this parts supplier the part number for the owner manual for the washer is MFL67737652.
If you click on the image of the manual in the link you will see that it is dated 01/05/2015.
Either it is the 5th January 2015 or the 1st May 2015, depending on the location where the date was written, so it may be around that time. (the link to the manual is from Kuwait which uses the UK date system of day first, followed by month but it may have come from the USA to Kuwait, if you get my meaning)
The washer is a rebadged LG washer (or perhaps a made for Kenmore by LG, washer) as all of the parts are LG parts.
Hopefully this is of some help
这个答案有帮助吗?
得分 1
添加一条评论
Per https://homespy.io
Based on the serial number provided, this KENMORE product was manufactured April 2016.
Supporting Model Data
Washer - White - 4.3 cu. ft. Top Load Washer w/Triple Action Impeller
$503 average listed price.
This KENMORE was manufactured by WHIRLPOOL
这个答案有帮助吗?
得分 1
添加一条评论
Hi @jennyloulequire
Your Kenmore 110.2922280 serial #CY1120800 washer was manufactured in March 2009
这个答案有帮助吗?
得分 1
添加一条评论
Hi @emmoes
Your washer most likely was manufactured by Whirlpool, in September 2020 or possibly September 2019 as the serial number you posted has multiple possible manufacture dates.
这个答案有帮助吗?
得分 1
添加一条评论
Hi @denniskizzire
Your washer most was manufactured by Whirlpool, in July, 2006
这个答案有帮助吗?
得分 1
添加一条评论
Hi @jasonowens57092
It was most likely manufactured in October 2015.
这个答案有帮助吗?
得分 1
添加一条评论
Model 110 25132411
Ser C54343896
Trying to figure out the manufacturer date
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
amy giacalone 将永远感激不已
浏览统计数据:
过去 24 小时: 17
过去 7 天: 123
过去 30 天: 577
总计 113,977
