跳转到主内容
加入维修社区 - 创建账户
于 2012 年 5 月发布,型号为 CE657A#BGJ。HP LaserJet P1102w 支持 USB 和 Wi-Fi 连接。
Why does it not print correctly
Hello. I have an HP Laserjet P1102w that prints clearly but whenever it prints the prints comes out in a slant way. I seem not to understand whats going on with the printer. I have cleaned the head and changed the toner but its the same result. I'm hoping I ll be able to find an answer here.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
Hi, Not trying to be smart, but have you checked that you are not printing whatever font you are using in "italics"?
由完成的 分享
添加一条评论
1个答案
I have several clients that have the same printer… usual fix is totally delete the printer. remove the USB cable, reboot and then see if the printer still shows. if yes again do a uninstall and remove from device & Printers. so that when you reboot you have NO PRINTER… then shut off computer, plug in printer cable. start computer and follow any instructions. it should AUTO start to install Printer.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
shobenboy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 22
总计 725
