跳转到主内容
MacBook Pro looses SSD after a while
I have bought a brand new ADATA SU800 SSD for my macbookpro (early 2011 running sierra).
I tried installing from USB but everytime after advancing for a while (even upto 80%) macbook looses SSD. All logs refer to be unable to write on the disk.
I use 'Disk Utility' first to remove partitions (works perfectly) but after loosing the disk, 'Disk Utility' doesn't see it. I also tried fdisk on the shell with the same result.
Here are some other facts:
1 - SSD is firmly secured.
2 - SSD works perfectly on my Windows and Linux desktop machine (I tried ADATA's test tool with quick test)
3 - SSD works on the mac when I boot from an external hard disk with macos installed but when I try to clone on it, it works but suddenly stops.
Anybody can help to work out this strange problem?
Thanks a lot
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Mine is working properly with the original HDD. It does not work with SSD due to 6gbs clock of SSD
完成的
添加一条评论
2个答案
已选择的解决方案
Change the hard drive/IR cable and install a 2012 model.
MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable
Here's how: MacBook Pro 13" Unibody早期 2011 硬盘连接排线更换
This cable connects a SATA I, SATA II, or SATA III hard drive to the logic board.图片
产品
$34.99
这个答案有帮助吗?
得分 4
7条评论:
What is IR cable? BTW, I'm connecting it to the ribbon cable inside the macbook pro. I don't think I can replace that cable easily. In the meantime, the cable works fine with original 320GB HDD and also works with SSD for about 30 mins before loosing it
完成的
Googled it.
How on earth the cable might be the cause? How can I be sure that it is the cable before changing it?
完成的
We have encountered many systems which need the new cable - Trust us! Its needed! Also use the newer version of the cable that Mayer posted you to (2012 model)
完成的
Most get damaged as they come over the last step, right the edge. If you look at the guide, this is a less than a ten minute job to replace.
完成的
So this is caused by cable damage not because of the SSD install?
完成的
显示更多的2条评论
添加一条评论
Did your issue solved?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Hossein Mohammadi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 1,358
