跳转到主内容
加入维修社区 - 创建账户
一款入门级笔记本电脑,具备基本的办公及影音娱乐性能,包含 G50-30、G50-45、G50-70 和 G50-80 等型号。
Bluetooth and USB cant connect
I don't know what happen but all of sudden my laptop can't connect to my phone via USB and also my laptop's Bluetooth isn't working correctly either! it doesn't work.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
Hi,
What is the exact model number of your laptop?
What OS is installed?
Have you checked in "Device Manager" that the BT is working properly?
Can you connect any other USB devices OK?
Have you checked the USB Controllers in Device Manager are OK?
Have you tried restarting the laptop at all?
What have you tried?
完成的
it say BT is not working properly my
My laptop only can connect via PTP not MTP
It is windows 8
完成的
Hi @nazri12330,
What is the "exact" model number of your laptop? This will help in finding the correct BT drivers for your laptop.
完成的
it is lenovo g40
完成的
添加一条评论
1个答案
已选择的解决方案
Hi,
Here is a link to the drivers for your laptop.
Select Bluetooth and Modem in the Component box on the page and then download the BT drivers and install them in your laptop.
Only download the BT drivers at this stage. Once you have fixed the BT problem you can go on and see what else needs to be fixed.
http://support.lenovo.com/au/en/products...
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
nazri12330 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 10
总计 652
