跳转到主内容
加入维修社区 - 创建账户
Static Fried DC-In Board?
During my routine of connecting the MagSafe connector to the MacBook, static hit the power connector on the MacBook. Immediately the battery read out in Mac OS changed to 'Not Charging' and the MagSafe LED indicator was dim green (on the newer kind, I have two) on my older one it flashes amber.
After doing some research everything seems to point to the DC-In Board. After the incident, the battery lasted another 3-4 hours (without any unusual signs, besides the 'not charging' message). Is my assumption on target? I have already ordered the parts from ifixit and awaiting their arrival.
Didn't want to go through the hassle of self-proclaimed "Geniuses" to troubleshoot this issue.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
There's no way for us to tell without opening it and testing with a multimeter. Try inserting the original system installation disk and start up holding down the "D" key. Replace what it tells you is bad.
这个答案有帮助吗?
得分 3
4条评论:
good answer +
完成的
Computer is not able to power up, now that the battery is flat. It will not start even when the charger is plugged in.
完成的
I was able to borrow my friend's battery and do the AHT. The AHT found nothing wrong. I will have the multimeter tomorrow when my replacement parts arrive, what should the readings be? on the DC-In board?
完成的
When the DC in board arrives i'd change that anyway. All your symtoms point to a fried DC in. If its still acting up you can at least rule out that cause.
完成的
添加一条评论
添加你的答案
Kirill 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 1,400
