跳转到主内容
加入维修社区 - 创建账户
由 Olympus 于 2011 年推出的一款 400 万像素超长焦数码相机。
internal battery or not
My camera lose its settings when i switch it on and off. does the camera have an internal battery that keeps the memory?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
Check that the All Reset setting is set to OFF.
Here is an image that shows how to get to the setting. Click on the image to enlarge it for better viewing.
Here is a link to the camera's user guide. Scroll to p.136 to see what settings are affected by the All Reset setting.
http://www.olympusamerica.com/files/oima...
Your camera does not have an internal battery to maintain the settings if the battery is removed. There is a non user replaceable capacitor mounted on the systemboard, which is kept charged by the battery and it will maintain the settings if the battery is removed for charging, but it only has enough charge to do this for approximately 24 hours. (It will be less then 24 hours if the battery has not been in long enough to fully charge it and then the battery is removed for whatever reason). After this time if a charged battery is not re-inserted back into the camera, the settings will revert back to their default state.
Hopefully this is of some help.
这个答案有帮助吗?
得分 3
1条评论:
It worked thanks. Operator problem. :(
由完成的
添加一条评论
添加你的答案
Francois 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 23
总计 1,038
