跳转到主内容
加入维修社区 - 创建账户
HP Split x2 是一款 13 英寸混合平板/笔记本电脑,于 2013 年年中发售。HP Split 的标志性特征是其可拆卸设计。
How do I fix my split x2 touchscreen
I mistakingly dropped my split x2 and the touchscreen got a crack, the screen still display fine but the touchscreen is not working. I can only use it with the dock and not as a tablet again. Pls where can I buy the touchscreen and how do I fix it
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
You may be out of luck.
Here is a link to the service manual for your laptop. Hopefully I have got the correct one.
http://www.hp.com/ctg/Manual/c03958968.p...
It shows that the touchscreen is part of the display panel and not a separate item. Scroll to p.17 &19 to view parts and part numbers. It also shows that the touchscreen board (not the 'screen') is not available as a spare part so hopefully it is OK (part #9 on p.17)
If you search online using just the part number of the display you will get results for suppliers of the part.
Below are just some examples, you might find others that suit you better. They are only shown to give you an idea of the cost depending on what type of display you have.
This is for a WVA display.
http://www.ebay.com/itm/LAPTOP-LCD-LED-S...
This is for a UWVA display
http://www.ebay.com/itm/HP-Split-X2-P-N-....
The service manual shows the necessary pre requisites and procedures for replacing the screen.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Kayode 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 1,046
