跳转到主内容
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
Cracked home button repair
My home button on my iPhone 7 plus is cracked and I can no longer use it! How can I get this repaired?
I am using the accessibility home screen button but would like to get the button fixed
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 17
6条评论
Only Apple can replace it and then pair the replacement button to the logic board. In contrast to older iPhone's now only the Touch-ID function but also the home button function is paired to the logic board on the iPhone 7.
完成的
Phone wizards can repair iphone 7 home button cracked or if the home button flex is broken they have done few repairs for me. 08003688181
完成的
Calvin. How much will cost me for you guys to repair my iphone 7plus The home button flex cable have a crack. Please. Send informations to. Dreams22us@yahoo.com
完成的
if finger sensor is working we offering home button repair if home button flex is damage then you should try apple store
https://www.kgnphonerepair.co.uk/
完成的
It my home button it need to be fixed
完成的
显示更多的1条评论
添加一条评论
10个答案
已选择的解决方案
TouchID will only work with the original home button. A replacement home button for the 4.7" iPhone 7 is already available on iFixit [关联产品丢失或禁用: IF332-002]
Follow these instructions for replacement:
更换iPhone 7 Plus的Home键/Touch ID
However, as the phone is almost brand new I would ask Apple how much they quote for a replacement.
Cheers
这个答案有帮助吗?
得分 5
9条评论:
It doesn't register when you press the button, so why bother even replacing it?
完成的
It's still in the first year. They might do something to help you
完成的
i also have this problem my iphone 7 plus was broken home button so how can i fix it in Cambodia
完成的
if i want to buy new home button so it work or not with my iphone 7 plus that broken home button
完成的
Get it to Apple, there is nothing you can do.
完成的
显示更多的4条评论
添加一条评论
最有帮助的答案
Do not replace the home button. The new button is ABSOLUTELY USELESS.
Go to Apple for repair.
这个答案有帮助吗?
得分 6
3条评论:
Thanks. I will be taking to apple
完成的
However what do you in the case that the original home button is broken. I installed an aftermarket home button (and am aware there's no touch ID function) but I don't even get regular button function after replacing it. Any suggestions? Does it seem like a defective button?
完成的
Just read the answer.
完成的
添加一条评论
I just had the exact same issue with a phone that was less than 30 days old. The phone was never dropped or damaged and had no issue besides the cracked home button. The first sign was that the touch id was not available and when I tried to push the home button to load to the home screen, the button literally cracked. I sent it to Apple only to be told that it was damage/misuse and not covered under warranty and would cost me approximately $319 (the out-of-warranty) fee for a repair!! Never buying an Iphone again...I'll stick with Samsung!
这个答案有帮助吗?
得分 2
1条评论:
And they replaced it for you? Would be good to know the Apple prices :) Especially since they have dropped their repair prices now the parts are cheaper on the market:
If your iPhone has additional damage that's not limited to the screen, see the "Other damage" fees.
iPhone model Screen repair only Other damage
iPhone 7 Plus A$ 228.95 A$ 518.95
iPhone 7 A$ 208.95 A$ 478.95
iPhone 6s Plus,
iPhone 6Plus A$ 228.95 A$ 488.95
iPhone 6s, iPhone 6 A$ 208.95 A$ 448.95
iPhone SE A$ 208.95 A$ 408.95
iPhone 5s, iPhone 5c,
iPhone 5 A$ 208.95 A$ 408.95
iPhone 4s See "other damage" fee A$ 308.95
All prices are in Australian dollars and include GST. We'll add a $A 19.95 shipping fee if we need to ship your iPhone. If we need to replace your iPhone, the replacement will be new or equivalent to new. If the issue with your iPhone was caused by severe damage from an accident or from abuse, service might not be available.
Identify your iPhone model
See iPhone service pricing in another country
Screen repair and accidental damage fees with AppleCare+
AppleCare+ includes two incidents of accidental damage coverage. You can use an incident for screen repair. Each incident has a service fee, as shown. The following prices are for Apple screen repairs with AppleCare+ accidental damage coverage.
iPhone model Screen repair only (AppleCare+) Other damage (AppleCare+)
All iPhones with AppleCare+ A$ 45 A$ 149
All prices are in Australian dollars and include GST. We'll add a A$ 19.95 shipping fee if we need to ship your iPhone.
If you don’t have AppleCare+, see our "iPhone screen repair pricing" fees.
Learn more about AppleCare+
Battery service
Your iPhone battery service might be covered by your warranty, an AppleCare plan, or consumer law. Otherwise, you’ll pay an out-of-warranty fee for battery service, as shown below.
Battery service In-warranty or with AppleCare Out of warranty
For all iPhone models A$ 0 A$ 119
完成的
添加一条评论
Hi the iPhone 7 / Plus you can swap buttons only if you have original button to swap out the ic chip on the flex cable attached to home button and you buy original home button as a replacement take the ic chip off solder the one from the original cable on to you new home button and bobs your uncle if you have thrown your old home button away apple it is for you but not for a cracked home button or torn flex cable swap ic chip good as gold again I did this with a ten pound solder iron and ome part and works fine take care in removing chip of the original it has a glue substance so remover first to heating it up use flux to separate from flex and pick it off carefully and if you do this clean I just pooped mine right on top when it cooled dawn got it perfectly lined up and turned on solder iron and wait ten and turn off heat let it sit for two mins and remove cool dawn ten mins pop on phone done if correct all done
这个答案有帮助吗?
得分 2
1条评论:
Are you sure you can replace the original button with another one? I cant see this sulotion in other websites.. Thanks!
完成的
添加一条评论
How much would apple charde for the repair?
这个答案有帮助吗?
得分 1
3条评论:
$129+tax in USA
完成的
Correction, 149 for plus model. 129 for regular
完成的
Has anyone checked the Apple Store price for the Home button replacement in Australia?
完成的
添加一条评论
Just happened to me too!! Crap
这个答案有帮助吗?
得分 1
添加一条评论
I care service center says need to replace touch screen with home button and it will cost 20.000 rupees
But I don't trust the way staff ask the question
这个答案有帮助吗?
得分 0
添加一条评论
Same as Samiam. NEVER another iPhone. Overrated crap. Back to Samsung for me.
这个答案有帮助吗?
得分 0
添加一条评论
Will the home button work if you put the original ic on the flex cable, to a new button?
Update (08/15/2017)
can the home button work if you replace the ic of the original flex, to the new button?
这个答案有帮助吗?
得分 0
2条评论:
Did you receive an answer?
完成的
I have just disassembled an Apple iphone 7 home button. I found a hidden ic chip under the fingerprint pad. It is glued in place with high temp resin. From what I have read, the ic chip on the ribbon does not store data, but is just a generic ic. I believe the answer to this will be removing the data from the original ic and then installing that data to a different Apple home button, possibly even an aftermarket one.
完成的
添加一条评论
If you’ve completely ruined your iphone 7 or 8 home button, and don’t want to pay apple to fix your stuff (because you’re a stubborn repair enthusiast like me), I believe you can find various replacement home buttons that function via bluetooth. The touch ID does not work, but at least you don’t have to use the little square. Seems this issue has been thoroughly answered, but I just wanted to add that in as an alternative answer to those of you who do not want to pay the $150 home button repair.
这个答案有帮助吗?
得分 0
1条评论:
It's called the JC home button. Apparently the version 2 is better.
完成的
添加一条评论
添加你的答案
krystalrose1021 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 112,891
