简介
iPhone 7 Plus 的 Home 键实际上是固态传感器,还包括Touch ID(指纹识别)功能。“
”大多数更换 Home 键将无法正常工作”,因此,在开始维修之前,请仔细检查。iPhone的原始Home 键在出厂时已与主板唯一配对,并且没有Apple专有的校准过程,即使是另一部 iPhone 的真正更换 Home 键也无法使用。要修复损坏的主页按钮,你应该安装特制的[产品|IF332-079|通用 Home 键]。请注意,更换后仅可作为按钮使用;Touch ID将不起作用。
如果你仅要更换破裂的屏幕,则可以使用本指南小心地将工作的原始Home 键拆除并将其转移到新屏幕,以保留所有功能,包括Touch ID。
在此过程中,为避免意外拉紧或撕裂显示屏电缆,最好在开始维修 Home / Touch ID 之前完全卸下显示屏部件。但是,如果你愿意,可以跳过本指南的“显示器组合件”部分,直接进入“ Home/Touch ID传感器”部分。
卸下四颗固定Home/Touch ID传感器支架的Y000螺丝。
一颗1.1mm螺丝。
三颗1.3mm螺丝。
重新组装时,请注意不要拧得太紧,否则Home 键可能不起作用。
56等其他人完成本指南。
特别感谢这些译者︰
100%
这些翻译人员帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
13条评论
Correct, and that is also stated in the introduction. This guide is primarily for folks who need to transfer the home button onto a new/replacement display. So Jeff if I'm transferring button to a new display will I retain Touch ID functionality? Or would it be lost? My screen is cracked and I want to replace it. Thanks.
Yes, if you carefully move your original home button to your new display, it should be good as new, Touch ID and all.
Hello,
The home button was cracked with keys in my pocket when it cracked the home button is started to heat when screen is turned off , when i use with display turned on the home button we not heat, Am wondering what could be wrong,
Any suggestion is appreciated
Does home button will work? after replacing with after-market home button, i just want know any one tried it?
i know touch id will not work.
Recently i have replaced the home button with after market, the phone will not boot up, just flashing with apple logo.
after replacing original it worked for me.
